Unit Power Pack custom battery ordering questions
dirt huffer   1 W
1 W
Post by dirt huffer » Aug 29 2018 8:14am
I will be ordering my first custom battery from Unit Power Pack (UPP) and am wondering if i'm missing anything. I'm looking to order a 72v 20s11p triangle pack (30Q), shrink wrapped with PVC with 50 amp BMS with balance charging, XT90 connector. I've gathered through reading this site that i should specify that I want 4 series connection at least between each parallel group? Am I missing anything else besides the dimensions of the battery (obviously)?
aroundqube   1 kW
Re: Unit Power Pack custom battery ordering questions
Post by aroundqube » Aug 29 2018 9:39pm
Charger ? and matching termination on pack charging leads .
flippy   1 MW
Post by flippy » Aug 30 2018 4:18am
why would you need to specify such things for a "professional" battery builder?
if you ask for certain discharge/charge specs one would assume they would build the pack to handle those currents with plenty of room to spare...
just asking....
Lithium beats liquid dinosaurs.
dirt huffer   1 W
1 W
Post by dirt huffer » Aug 30 2018 9:06am
flippy wrote:
Aug 30 2018 4:18am
just asking....
Sometimes people have helpful recommendations to ask for.... like asking for a spare BMS with your order. :roll:
flippy   1 MW
Post by flippy » Aug 30 2018 11:42am
dirt huffer wrote:
Aug 30 2018 9:06am
if you burn out the bms i would not fit the same one again...
i woudl ask for external balance wires.
dirt huffer   1 W
1 W
Post by dirt huffer » Sep 01 2018 4:51pm
flippy wrote:
Aug 30 2018 11:42am
dirt huffer wrote:
Aug 30 2018 9:06am
That's a good idea. Looking into it more i dont think im going to use a BMS. I think ill have them make two 10s6p batteries with a series connector, external balance wires, and charge them with a balance charger - like dual iCharger 1010B+
I like what this guy has to say about battery building without a BMS https://www.youtube.com/watch?v=pljSZcEwc8Q&app=desktop
flippy   1 MW
Post by flippy » Sep 01 2018 6:17pm
Sorry but that is still dumb.
Dont confuse that no bms is better then having a shit bms. Just get 1 good one. Check che blutooth bms thread for some pointers. One bms even has the option for a lcd, speed indicator and remaining range and can be bought without mosfets so you can solder in your own good ones.
999zip999   100 GW
Post by 999zip999 » Sep 01 2018 8:34pm
11p of 30q you can learn how to self manage and be your own bms with a C.A. and sense wires. Just bulk charge and check with the sense wires.and a una6plus+ thru the sense wire balance charger if unbalanced after end of charge. Quality cells stay balance if used properly.
tomjasz   10 GW
Post by tomjasz » Dec 19 2018 6:34pm
Customer sent UPP battery to German repair facility in early October. No response, no update, and UPP takes no responsibility nor bothers to update customer.
amberwolf   100 GW
Post by amberwolf » Dec 19 2018 8:14pm
tomjasz wrote:
Dec 19 2018 6:34pm
It would be nice to hear from Dirt Huffer about the specific problems the pack had that required it be sent all teh way to Germany for repair, so soon after purchase (less than a month, presuming shipping only took a week or two after the last posts before yours).
