Charging 12v SLA with Li-Ion charger?
smaua   10 mW
Post by smaua » May 09 2017 2:24pm
hey all, i`m sorry if this is a silly question but i tried searching and googling and i`m still a bit confused as it's been hard to find my specific situation
basically i have a 12v 8aH SLA that im trying to use for an electric vehicle i`m playing with, but there's no charger. I`m not really looking to buy one as it's just a toy vehicle and i want to just do it for free if it's possible.
I've also got one of these : http://www.ryobi.com.au/products/detail ... rt-charger
was reading about how charging a 12v SLA u need a bit more than 12v, and this ryobi charger says 14.4-18. but maybe it's more complex than that..
obivously they are completely different types of batteries but i`m wondering if this charger would be intelligent enough to charge the SLA without damaging it (too much)?
thanks for reading!
edit: ive been reading a bit more about this and i thought i should say i also have a multimeter and i could monitor the voltage with it if that makes it safer
dogman dan   100 GW
Re: Charging 12v SLA with Li-Ion charger?
Post by dogman dan » May 12 2017 5:39am
That would only work if your 12v battery had the same electronics inside it that your Ryobi packs have.
You can buy a 12v trickle charger, very slow, for about 5 bucks though. Or use a 2 amps car charger, a bit more expensive. (harbor freight, or ebay)
The best investment you could make, would be to invest in a small, inexpensive RC charger. Something like an Imax B6. With that, you will have a fairly slow charger, 50 watts, but it will be able to charge any chemistry battery you get in the future, up to about 24v.
BTW,, if you do that, set the charger for 2 amps for that 12v lead.
smaua   10 mW
Post by smaua » May 17 2017 1:35pm
Thanks! thats cool advice..i`ll look into the rc charger cause that would be super handy. just realised i could wire my ryobi battery instead of the SLA so that makes everything much easier and faster.
