New Chargery BMS24
johnnyz   1 kW
New Chargery BMS24
Post by johnnyz » Mar 03 2017 9:41am
I just received my new Chargery BMS24 unit. Need some ideas on how to set up the charge and discharge port.
here is a diagram of the set up..
In order to set up the charge and discharge port it would require a relay. Does anyone have any ideas on what I could use for this?..The shunt that was given with the unit is a very heavy duty unit and I will be pulling a max of 60 amps using 24 Li-Ion cells (100 volts).
If anyone has had any experience with this I would appreciate any comments..this looks like an exciting product and cant wait to test it out
Thanks
John
Doctorbass   100 GW
Re: New Chargery BMS24
Post by Doctorbass » Mar 03 2017 10:12am
wow.. that tool look very interesting!..
24s !
? PRICE? WHERE TO BUY ?
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
johnnyz   1 kW
Post by johnnyz » Mar 03 2017 3:24pm
Doctorbass wrote:wow.. that tool look very interesting!..
24s !
Doc
Hey Doctor Bass
Here is the website....http://www.chargery.com/
The price was $216 US including shipping and all the accessories...I am not sure of how to set up a relay so that a charger can work and set up another relay for discharging although the Shunt is good for 300 amps!!!
Cant wait to see how this works!
John
johnnyz   1 kW
Post by johnnyz » Mar 03 2017 5:03pm
Wow...looks like that will do it although the relay for charging looks abit overkill..
Thank you!
skeetab5780   10 MW
Post by skeetab5780 » Mar 03 2017 5:10pm
What is this thing? How the heck can it charge at 600a is that per cell or 24cells divided by 600? It seems fairly complex and bulky so it almost seems like a component meant to be permanently installed next to a battery and take the place of a bms?
major   10 kW
Post by major » Mar 04 2017 11:25am
24s !
Doc
Hey Doctor Bass
John
Hi John,
Thanks for sharing. I'm very interested. Keep us posted, please. Did you purchase directly from Chargery? Also noticed it needs power supply of 15 to 40? Volts (1 Amp max) IIRC. I assume PS needs to be isolated. Any idea if it can use automotive aux 12-14V? I'd like to use on EVcar. PITA to need seperate PS just for BMS.
major
amberwolf   100 GW
Post by amberwolf » Mar 04 2017 2:02pm
FWIW, there is a thread in the for sale section for this unit, by Inwo.
major   10 kW
Post by major » Mar 05 2017 12:36am
Thanks AW......
johnnyz   1 kW
Post by johnnyz » Mar 05 2017 4:09pm
Ill be hooking this up to my 24s li-Ion battery in about 2 weeks..because I have been manually balancing the cells using the battery medics I have been getting about 35-40 kms per charge. I can use as much as 33 wh/km and as low as 22 wh/km. Pulling 55 amps and about 4200 watts. I believe that my range should increase as a result of this device and cant wait to try.
I will be updating the results as soon as I can, although I am not sure where I am gonna put it...
Motorino XMR modified..
johnnyz   1 kW
Post by johnnyz » Mar 08 2017 10:27am
I have decided that I am not going to have a relay connected to the discharge port but only the charging port as the unit has 2 different alarms with regards to LVC and drawing 60 amps through a relay generates to much heat especially where I am going to put the relay.
Charger is a 24s lipo (100 volts) at 5 amps
Vendor said that the charge controller port will put out either pack voltage or if an external power supply is used,what ever that voltage is..example 16 volts..
Ok I am assuming that this relay ( for charging port only) would work?..
http://www.ebay.com/itm/Crydom-TD1210-S ... SweWVXf7Dq
Input is 3-32 volts
Output is 120 volts
Any thoughts?
Thanks
John
kocetoMR   10 W
Post by kocetoMR » Mar 08 2017 1:39pm
johnnyz wrote:I have decided that I am not going to have a relay connected to the discharge port but only the charging port as the unit has 2 different alarms with regards to LVC and drawing 60 amps through a relay generates to much heat especially where I am going to put the relay.
Input is 3-32 volts
Output is 120 volts
Any thoughts?
Thanks
John
https://www.youtube.com/watch?v=bzrsE4tTJP8
You must put relay output.The BMS24 contol output and charger relay,when have problem with battery BMS24 cut voltage.I apologize for my bad English
johnnyz   1 kW
Post by johnnyz » Mar 08 2017 2:46pm
"You must put relay output.The BMS24 contol output and charger relay,when have problem with battery BMS24 cut voltage.I apologize for my bad English"
The input to drive the coil in the relay is 3-32 volts and the output is 120 volts..(I will be using an external power supply because if not, what would be coming out to drive the relay coil is battery voltage and thats too high)..(im assuming that that is the MAXIMUM as my charger only puts out 100 volts and 6 amps
John
Bikegirl   1 W
1 W
Post by Bikegirl » Sep 25 2019 9:22pm
Hi guys, my husband and I recently bought the chargery bms 24t to charge our 72v 20s2p lipo battery.
I have found that it is not balancing well. Does anyone know if there is any more info on the balancing logic or anything that can be modified to help with focussed balance charging?
Thanks
Amy
yewsuck   10 mW
Post by yewsuck » Sep 26 2019 2:54am
Delete double post
yewsuck   10 mW
Post by yewsuck » Sep 26 2019 2:56am
The only way I know to improve balancing is to open the cover and add thermal paste or a thermal pad so that the balance resistors can transfer heat away to the case. Balancing current is limited by heat.
NOTE:
There are a few models with similar names mentioned in this thread.
BMS-24 does not have balance functions only monitoring and relay control.
BMS-24T or BMS-24PRO are a two piece unit that also has balancing besides the monitoring and relay control.
