Charger voltage adjustment
Jimboyr6   1 kW
Post by Jimboyr6 » Aug 05 2016 1:52pm
Does anyone know which ones voltage adjustment ?
1-2-3 or 4
Stealth bomber owner 138 livin the dream
Schlafmutze   10 W
Re: Charger voltage adjustment
Post by Schlafmutze » Aug 05 2016 2:37pm
How can anyone know if we don't know what charger it is??
The way I get around this is to measure the output, then slowly turn each pot until the voltage moves, though if it doesn't move adjust back to where it started.
Jimboyr6   1 kW
Post by Jimboyr6 » Aug 05 2016 3:54pm
This is the charger its from em3ev,u can only adjust it when its plugged in to a battery
Jimboyr6   1 kW
Re: Charger voltage pot adjustment
Post by Jimboyr6 » Aug 10 2016 1:51am
Fyi
Its number 3 pot i plugged into my pack and with a voltmeter on the output turned pot clockwise but what i found is you have to get it passed ur desired voltage then go back very slowly untill charger cut out,more then back, more then back to get the cut out spot on
