Westart 20AH pouch cell
sigimem   100 W
Post by sigimem » May 13 2016 6:40am
Hope you don't pick on me but some guy posted on facebook :roll: battery data and it looked very interesting.
Is something like this available right now? Or are these just impressive numbers that are not real?
Hillhater   100 GW
Re: Westart 20AH pouch cell
Post by Hillhater » May 13 2016 9:00am
Nothing exceptional....unless its very cheap ??
Very similar spec to the A123. 20Ahr pouch that has been available for 8 or more years.
alf66   1 µW
Post by alf66 » May 14 2016 4:35am
How much cost ? :oops:
cycleops612   10 kW
Location: Sydney Australia, Me: 70kg/154lb. 350w, 22kg ex battery, 24 speed axial mid-drive Bofeili MTB.
Post by cycleops612 » May 14 2016 11:52am
Yet ~nobody seems to make a finished product (kits-cells/case/charger etc.) which reflect these bold claims?
(edit, as you were on the above. I missed that it was graphene (? - dunno), not lifepo4)
still, re lifepo4:
they charge at a wimpy .2 or .4c, and output at 2c max usually
I cant help thinking those dopes are being over protective re longevity of the battery. the cells can do 3c but we are restricted to 2c e.g. more worried about warranty than performance.
frankly, i dont give a damn if i drop 500 of my rated 2000 lifetime charges due to fast charging when it suits me.
pushing the boundaries a bit can save many from some kilos of onboard battery weight and cost.
Thats just how it seems to this casual observer of the market.
999zip999   100 GW
Post by 999zip999 » May 14 2016 12:34pm
Can somebody find a price ?
cycleops612   10 kW
Post by cycleops612 » May 15 2016 5:02am
nitpicky, but widthe of pouch could, to all intents, be up to 2cm exaggerated. The seams dont use space in the case, they fold aside.
999zip999   100 GW
Post by 999zip999 » May 15 2016 10:52am
Anyone get a price per cell for 14 or 20s ?
sigimem   100 W
Post by sigimem » May 18 2016 7:06pm
On Facebook the guy stated 27 $ per Cell. He was asked for 100 Cells so maybe It´s more in smaller quantities.
Thats the main argument for these cells I guess
Animalector   10 kW
Post by Animalector » May 19 2016 1:16am
is there something wrong with their lifecycles chart... 400, 600, 800, 1000, 2000 in equal increments?? typo? i.e 1200??
Anyway
Andy
miro13car   1 MW
Post by miro13car » May 19 2016 3:40pm
Just quick glance at discharge curves,
A123 cells have MUCH flatter discharge curves.
Of course A123 is LiFePo , those are not, NMC???
cycleops612   10 kW
Post by cycleops612 » May 19 2016 10:19pm
miro13car wrote:Just quick glance at discharge curves,
I dont really get it either, but they are pouch construction, which i like a lot- simple and huge, flexible cells vs cannister
i need to bone up on graphene to have any opinion it seems.
999zip999   100 GW
Post by 999zip999 » May 19 2016 10:44pm
What are the tabs as A123 has one aluminum and one copper and can't be easily welded. I bolt mine together and works great and can exchange cells if needed. If 25.00 a cell I'm interested. Cycles 5,000 ??? What plus that 5 looks different.
cycleops612   10 kW
Post by cycleops612 » May 20 2016 9:34am
999zip999 wrote:What are the tabs as A123 has one aluminum and one copper and can't be easily welded. I bolt mine together and works great and can exchange cells if needed. If 25.00 a cell I'm interested. Cycles 5,000 ??? What plus that 5 looks different.
me too-$300 for 12 cells, 20 amps 36v seems pretty fair, under 450 one hopes delivered in a case in OZ, is about the right money for lesser ifepo4s.
i think 15 amp would do me tho.
but what is the verdict on graphene guys, its new to me?
icherouveim   1 kW
Post by icherouveim » Jul 15 2016 9:17am
Hello Guys,
this Company is one of the best.
Actually I am running their Cobaltium 20AH cells for the last year and the quality is exceptional.
I draw about 70A the most of the time till the cells will be 3V and after one year of hard use they haven't lost any capacity.
I've installed them into my new flux beta and they still run like brand new!
I am planning to buy their new Graphene cells as they support fast charge, longer cycle life and they are smaller.
Someone said they are at the market for the last 8 years, They don't know what they say, this is a very new chemistry.
after a serious research and many tests with other cells those are the best I've found at the best price.
Ioannis
jumpjack   100 W
Post by jumpjack » Oct 10 2016 3:17am
999zip999 wrote:Can somebody find a price ?
I received this quotation:
NCM cell: 3.7V30Ah: US$32.4/set.
Graphene cell: 3.7V20Ah: US$23.6/set.
Which means 292 $/kWh for NCM and 319 $/kWh for graphene.
It's look a little "invented".... First interval is 400, next ones are 200, then it's 1000.... :?
Anyway I read a paper about NCM being capable of 4000 cycles.
NCM cells have also 180-200 Wh/kg (these cells: 205 Wh/kg) and 400 Wh/L.
Summary:
1/2 cost of LiFePO4
2x life vs LiFePO4
2x Wh/kg LiFePO4
It's like saying 1/4 lifetime cost or 4x lifetime (*) vs LiFePO4 for a smaller and lighter battery. :D
Anyway beware of ready-made "batteries" offered by Westart! They do not look like batteries at all... They look like just groups of cells enclosed in plastic and connected to a BMS. They're very far to be acceptable as automotive batteries, which must sustain strong accelerations and vibratrions for years.
(*) In terms of total kWh delivered during lifetime.
icherouveim   1 kW
Post by icherouveim » Dec 06 2016 4:36am
Hello guys!
After the big success of their cobaltium cells I've decided this time to build a smaller battery pack with 10AH graphene cells for my second small ebike I have it just for fun.
(I wanted something lighter for small rides mostly for ladies). I couldn't solder the tabs this time because one of the poles is made by aluminium so I had to use small screws, later on I've found out that you can order the cells with different metal in order to be able to solder them properly.
I am really impressed with the results, battery pack is connected with an unlocked adaptto mini-e controller, I draw about 100A this is about 6kw of power from this little baby!
I attach some photos and a video.
https://www.youtube.com/watch?v=mPWesnkex3k
999zip999   100 GW
Post by 999zip999 » Dec 06 2016 7:03am
So how much for the 10ah cells they have 20ah ? Price and link. Looks good what size is it ?
The link above worked. What is the tab material. I don't mind walking the tabs together with aluminum blocks in between.
What you're watching the u.s. election in the background I would have to turn off the TV myself.
icherouveim   1 kW
Post by icherouveim » Dec 06 2016 11:37am
Haha you know how euronews channel is, they change subject every two minutes. I Don't like to watch US election either.
So you can speak with Mrs. Kelly to give you a quotation for the cells u want plus shipping cost to your country.
Yes they have 20ah graphene cells also (They are capable of 200A continuous!)You can find the sizes of the cells at their website.
Skype : kelly.hu06
Website :http://www.szwestart.com/ProductView.asp?ID=1082
westartbattery   1 µW
Post by westartbattery » Dec 07 2016 12:08am
the positive tab material is aluminum, the negative tabe material is copper.
999zip999   100 GW
Post by 999zip999 » Dec 07 2016 11:35am
Welcome to E.S. look forward for tech information and talk. My A123 20ah pack has copper and aluminum tabs, I just bolted tabs Between aluminum and plastic blocks. 950 cycles great for a bike. As a vendor don't post price here Only in for sale thread or mods could lock these thread up. Pm my with price if you can.
cycleops612   10 kW
Post by cycleops612 » Dec 07 2016 12:25pm
westartbattery wrote:the positive tab material is aluminum, the negative tabe material is copper.
do you understand that "grephene" is not correct english spelling?
Hillhater   100 GW
Post by Hillhater » Dec 07 2016 3:36pm
..and can you spell it correctly in Chinese ? :wink:
cycleops612   10 kW
Post by cycleops612 » Dec 07 2016 4:49pm
yus bit ut mite meen lost sayles to them einstein. Can u say "search string?"
Hillhater   100 GW
Post by Hillhater » Dec 07 2016 5:39pm
Its a forum , ( with a crap search function at that !)......not the Oxford English Dictionary, Battery definitions sub section !
For someone using english as a second ( or maybe 3rd or 5th language). I recon Westart was doing pretty good . :roll:
cycleops612   10 kW
Post by cycleops612 » Dec 07 2016 6:11pm
Hillhater wrote:Its a forum , ( with a crap search function at that !)......not the Oxford English Dictionary, Battery definitions sub section !
what on earth has this forums search engine anything to do with?
do you really think having the key word for his product misspelled is not going to risk missed hits from searches generally? Astonishing. Good day sir.
