Bring SLA batteries inside for winter?
Davets   10 µW
10 µW
Post by Davets » Oct 06 2014 3:06pm
Wondering what the conventional wisdom on SLA batteries staying on a bike during winter is. I live in Minnesotw, where it's not uncommon to see 0 or -10 F some weeks. Will these temps damage SLA batteries? I would think not as I think these are what is in my car too, but unsure... Thanks for any help?
tomjasz   10 GW
Re: Bring SLA batteries inside for winter?
Post by tomjasz » Oct 06 2014 3:19pm
Absolutely! And top off with distilled water and put on a maintenance charger, 1-2 AH, for best life. I have some 6 year old batteries maintained in SE MN.
tomjasz   10 GW
Post by tomjasz » Oct 06 2014 3:20pm
BTW where in MN. Winona here.
Schlafmutze   10 W
Post by Schlafmutze » Oct 06 2014 3:20pm
Bring all the batteries inside during winter, unless you're planning to store them.
dnmun   100 GW
are you close to minneapolis?
Post by dnmun » Oct 06 2014 4:25pm
http://www.ebay.com/itm/281454339635?_t ... EBIDX%3AIT
you could use a battery warmer to keep the batteries from getting cold too.
Davets   10 µW
10 µW
Post by Davets » Oct 20 2014 2:40pm
I suspected that it's a good idea to bring them inside, but I was surprised that the heat, more than the cold, seems to be the damaging factor. Thanks very much for the detailed responses and happy riding!
Dave
Ypedal   100 GW
Post by Ypedal » Oct 20 2014 3:06pm
Just make sure they are fully charged and leave them in the cold imo.
ES site status page:
tomjasz   10 GW
Post by tomjasz » Oct 20 2014 4:30pm
While I'd never criticize your experience it's contrary to most manufacturers. 15°C (59°F) is a typically recommended storage temp.
Davets   10 µW
10 µW
Post by Davets » Oct 20 2014 4:59pm
Perhaps a mild winter would be acceptable, but in the Twin Cities, MN, it often reaches 0 deg F (or -10!) for weeks at a time.
dumbass   100 kW
Post by dumbass » Oct 20 2014 5:07pm
I live in the Chicago area and I bring my SLA car battery in every night and keep it warm by the fire place. SLA batteries do fine in the cold as long as they are kept charged.
Bob
Ypedal   100 GW
Post by Ypedal » Oct 20 2014 5:30pm
If you need to use them, yes, they need to be kept warm prior to being used or the voltage will sag to nothing.
but if they are to be kept un-used for the winter months, fully charged, cold temps are fine imo.
tomjasz   10 GW
Post by tomjasz » Oct 21 2014 3:53pm
Ypedal wrote:If you need to use them, yes, they need to be kept warm prior to being used or the voltage will sag to nothing.
Well they won't freeze but it is hard on the flooded cells. Again 59F is the industry standard. I've a lot to learn about lithium but having managed fleets of SLA and LA batteries, you will get a longer life out of a properly stored battery. I'm cheap! :wink:
tomjasz   10 GW
Post by tomjasz » Oct 21 2014 3:54pm
Davets wrote:Perhaps a mild winter would be acceptable, but in the Twin Cities, MN, it often reaches 0 deg F (or -10!) for weeks at a time.
Thanks for the reminder!
