Cheapest ebike charger
ian.mich   10 kW
Post by ian.mich » Jul 15 2012 9:01pm
I'm looking for the cheapest 500W ebike charger. Needs to be customized by myself or the manufacturer. I'm tired of the expensive BMS battery and Greentime chargers.
cal3thousand   1.21 GW
1.21 GW
Re: Cheapest ebike charger
Post by cal3thousand » Jul 17 2012 7:36pm
BMSBattery charger is expensive? How much are you looking to spend then?
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
ian.mich   10 kW
Post by ian.mich » Jul 17 2012 11:12pm
cal3thousand wrote:BMSBattery charger is expensive? How much are you looking to spend then?
$50-60. The only way this is achievable is if i did a meanwell.
grindz145   100 MW
Post by grindz145 » Jul 18 2012 12:51pm
That's even hard with a meanwell...
ian.mich   10 kW
Post by ian.mich » Jul 18 2012 4:48pm
grindz145 wrote:That's even hard with a meanwell...
Not really, a local ebike guy built a 500w one for $44 including parts. he didnt charge me for labour tho cause i bought other stuff from him.
1.21 GW
Post by cal3thousand » Jul 18 2012 4:53pm
Don't cheap out on the charger, especially with LiPo.
It's the one real area where a fire is most likely. Deep discharges hurt the battery, over charges can cause fires.
ian.mich   10 kW
Post by ian.mich » Jul 18 2012 5:04pm
cal3thousand wrote:Don't cheap out on the charger, especially with LiPo.
Fair enough, but this meanwell is more reliable than the Greentime chargers that i've used, and if you set it to 4.15/cell, then it will take forever to get to 4.20 (never stops charging, just gets to extremely low amps)
1.21 GW
Post by cal3thousand » Jul 18 2012 6:49pm
Looks like you found the cheap one.
But for everyone that can't find someone to build one at that price, I believe that BMSBattery is a great deal. Then there's also the balancing charger that was recently found by Hyena. Someone found what seems to be an identical one on DealExtreme:
http://www.dealextreme.com/p/bc168-1-6s ... ger-124483
Hillhater   100 GW
Post by Hillhater » Jul 18 2012 7:30pm
But you are only "bulk " charging, so still high risk unless you have a BMS or some other cell level monitoring available.
Cheap ..Reliable,.. and Safe ..are a tricky combination to find in a charger.
ian.mich   10 kW
Post by ian.mich » Jul 18 2012 9:43pm
I disagree. I and the local ebike guy use the 4S turnigy hardcases and there has not been evidence that balance charging is necessary. we just parallel all the cells every 10 cycles and there are no issues, i even left a pack unparalleled for a month (fried a JST) and the pack was just as balanced as the ones that had been parallel. we make the parallel boards using these
http://www.hobbyking.com/hobbyking/stor ... _bag_.html
and a prototype board. snip off the male end and parallel all the same colours, cover the solder side with silicone.
dingoEsride   100 kW
Post by dingoEsride » Jul 18 2012 10:02pm
cal3thousand wrote:But for everyone that can't find someone to build one at that price, I believe that BMSBattery is a great deal. Then there's also the balancing charger that was recently found by Hyena. Someone found what seems to be an identical one on DealExtreme:
Ive got the same, $120 is cheap for a good one that balances imo anything that doesn't can be dangerous or cost you more in the long run
ride like the wind
ian.mich   10 kW
Post by ian.mich » Jul 18 2012 10:24pm
or you could have gotten a BMS battery charger and paralleled every 10 cycles, and charged with 3 times the power.
Hillhater   100 GW
Post by Hillhater » Jul 18 2012 10:44pm
ian.mich wrote: I disagree. I and the local ebike guy use the 4S turnigy hardcases and there has not been evidence that balance charging is necessary. we just parallel all the cells every 10 cycles and there are no issues, i even left a pack unparalleled for a month (fried a JST) and the pack was just as balanced as the ones that had been parallel. we make the parallel boards using these
Yes, I agree, that is exactly as i do also.
BUT.. when you BULK CHARGE you risk a single cell failure going undetected.
If/when that happens you could quickly overcharge a whole group of cells.
.....UNLESS you have cell level monitoring.
ian.mich   10 kW
Post by ian.mich » Jul 18 2012 11:53pm
Yes, that is true, but it's not every day that a cell goes bad. and lipos are tolerant. the ebike guy charged to 4.5/cell and still uses the same lipos to this day. Personally i charge to 4.15/cell because i don't use the range I have, and I set my customers up with 4.17/cell.
John in CR   100 GW
Post by John in CR » Jul 19 2012 1:41am
You want to sell hubmotors with oil in them, and you're selling packs made with RC Lipo with bulk charging and no cell level monitoring or cut-off. I hope you're saving up money for a lawyer, because you're going to need one.
ian.mich   10 kW
Post by ian.mich » Jul 19 2012 7:51am
John in CR wrote:You want to sell hubmotors with oil in them, and you're selling packs made with RC Lipo with bulk charging and no cell level monitoring or cut-off. I hope you're saving up money for a lawyer, because you're going to need one.
thats how i roll. i test all the lipos beforehand and there is no reason to run bms or cell monitoring. the local ebike guy does precisely the same 2 things and has perfected oil cooling, now i just have to do the same. And i do run LVC in the controller for 3v/cell.
ZOMGVTEK   100 kW
Post by ZOMGVTEK » Jul 19 2012 8:18am
The only way you can get away with bulk charging LiPo with no cell level protection or monitoring, is if you accept the increased risk of fire, understand the chemistry you are using, and have a very good mental BMS.
If a single cell gets a little weak over time, which is exceedingly likely, it will discharge to a lower voltage in respect to the others. If you try and get deep discharges out of your entire pack, this will pull that cell well out of its normal range. This will likely degrade capacity in that single cell dramatically. The issue here being, you have no active monitoring or balancing, and the bulk charger has no knowledge of individual cell voltages, so it will force current into the bad cell. If this goes unnoticed, it can very likely result in fire.
This is fine if you decide to do this, but selling 'tested' batteries to someone that you claim need absolutely no monitoring or balancing, is absolutely insane. Do this long enough, and you will burn someones house down. People need to understand there is HIGH risk when using RC LiPo like this. Sometimes these cells can appear to be fine, and go up in flames under normal use. Rare, but it occurs.
That said, I bulk charge my pack, and have no BMS. However, I bulk charge to 4.10V average, check the cells before connecting the bulk charger, and typically end discharge at 3.75V with a 3.65V average LVC. I charge my bike where fire would not be a big deal, and they have been extensively cycled, tested, and capacity/IR matched.
3V/cell average LVC is absolutely insane for a system without a BMS or cell level monitoring. It would be VERY easy for one cell to be repeatedly discharged lower than the rest, degrading capacity at a higher rate than the rest of the pack, further increasing the unbalance at low voltages. Cell capacity at 3V is absolutely tiny, minor imbalances cause major problems. 4.15V bulk charge voltage is a bit on the high side too.
ian.mich   10 kW
Post by ian.mich » Jul 19 2012 8:30am
ian.mich   10 kW
Post by ian.mich » Jul 19 2012 8:33am
ian.mich wrote:
ZOMGVTEK wrote:The only way you can get away with bulk charging LiPo with no cell level protection or monitoring, is if you accept the increased risk of fire, understand the chemistry you are using, and have a very good mental BMS.
there isn't no cell monitoring, I inform them of the risk and tell them to parallel the packs every 10 cycles as well as check cell voltages regularly so its not like i'm saying they need no balancing. this is a risk but i keep the customers educated and make sure they know what they're getting in to and that they keep an eye on it. It is true i dont have a real LVC (3.5/cell), but I keep a voltage panel easily visible to the customers at all times and tell them not to go below 3.5
motomech   1 GW
1 GW
Post by motomech » Jul 19 2012 10:14am
Wow, pretty smug attitude, how long have you been doing this?
Putting your property and well being at risk by your naivete is one thing, but advising others to do the same is unconscionable.
Even running a MeanWell[that doesn't shut off]without physically monitoring has it's risk.
Hard for me to imagine what kind of ebike business can be promoted by advocating the "cheapest"Lipo charging solution.
I mean, what are we saving here?
My B system which will 12S balance charge @ 300 Watts, set me back a whole $105 :roll:
Motomech
'07 GT Idive 4 4.0, Q100H 201 frt. mounted, 14S Multistar LiPoly, elifebike 9-FET 20A controller. Mean Well HLG-320H-54A, Crazy Bobs on Alex DM32's 21 to 22 MPH. viewtopic.php?f=3&t=28151&p=1373714&hilit=Idrive#p13737
ian.mich   10 kW
Post by ian.mich » Jul 19 2012 10:44am
motomech wrote:Wow, pretty smug attitude, how long have you been doing this?
I'm not being smug i'm just saying it's unnecessary to complicate a simple charging system. for $100 you coulda got a 600W charger and just paralleled every 10 cycles, and if you wanted to do 24s you'd need two of those or parallel the cells. I'm not trying to do just the cheapest, i also want some decent safety to it which is yielded with the meanwell limiter. I haven't been doing this for terribly long but am essentially basing my systems off the ebike guys, he's likely sold around a thousand of the hardcase lipos and never had issues with the bulk charging and paralleling.
dnmun   100 GW
Post by dnmun » Jul 19 2012 11:29am
smug is not the right word. ignorant of the experience these experts have offered is more like hard headed.
make that two lawyers, one for the motors and one for the chargers. then another for the divorce.
this is why i never rent to guys anymore. one lipo fire in my house in a lifetime is more than enuff.
cheap at someone else's expense.
ZOMGVTEK   100 kW
Post by ZOMGVTEK » Jul 19 2012 12:01pm
I bulk charge for the simplicity of wiring the packs. Split the HXT's and series until you get to the final voltage you want. No harness required.
The only issue with this method, is that you need to charge at the full pack voltage, and can't parallel all the balance taps.
Regardless, selling a dangerous chemistry battery to someone who is apparently incapable or unwilling to make it themselves, with absolutely no way of balancing even a slightly imbalanced pack is insane. You can tell someone to parallel balance taps every 10th charge, but will they even do it? Do they know why they need to? Do they leave the packs paralleled long enough to even be effective past all the resistance of the balance taps and connectors? How do you know the plugs are not worn and no longer balancing? Do they check the voltage before plugging in the bulk charger? Do they know to toss the battery if a cell goes below 3V? Do they know never to bulk charge unattended, or to disconnect the charger after its done charging? How do they monitor charge status? How do they know when the battery is in need of a charge?
I understand that many people can get away with stuff like this, and its you are probably knowledgeable enough to not have major issues. Well tested/balanced LiPo does tend to be a bit easier to manage than most people claim. However, its just far too risky to start making people packs out of this stuff. If they want a cheap battery and charger, they can make it themselves, or just give them lead.
ian.mich   10 kW
Post by ian.mich » Jul 19 2012 12:45pm
I give up.
nicobie   10 MW
Post by nicobie » Jul 19 2012 12:48pm
You want a cheap ballancing charger and are not afraid to solder up a couple plugs, buy as many $17 HK 6s chargersas you need to match your pack.
This one is for 18s and I only use it every couple of weeks. It's ugly but it works. However I do check each 3p pack with a battery medic quite often.
Take it easy... but take it. (Woody Guthrie)
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
