48v 20ahr aliexpress jungla brand
whatever   100 kW
Post by whatever » Mar 25 2020 11:37am
anyone experience with these, they are cheap
https://www.aliexpress.com/item/4000596239155.html
docw009   100 kW
Re: 48v 20ahr aliexpress jungla brand
Post by docw009 » Mar 25 2020 11:51am
The ad says it's 13S3P, which means 13 series, 3 cells in parallel, The last number is used to determine the AH, and the total capability of those three cells is your AH.
Hmm, 20AH and 3P means each cell puts out 6.66AH. That's impossible right now. Maybe in a few years. So the ad is lying to you,
john61ct   100 GW
Post by john61ct » Mar 25 2020 2:34pm
yes scammers
dogman dan   100 GW
Post by dogman dan » Mar 26 2020 5:52am
yeah, zero chance that's 20 ah.
I'll never stop saying it, never trust cheap cells. Burn your house down. Likely that pack is more like 8 or 9 ah, and 6 or 7 ah in actual usable capacity. It will sag like grannies tits. Its a hoverboard battery basically.
But 4 of them in paralell, that's a possibility. Just keep em outside!!!
Lastly, your money will travel to china easy. The battery not so easy at this moment. So don't send your last hundred bucks, send the money you would have spent in a bar.
999zip999   100 GW
Post by 999zip999 » Mar 26 2020 10:47am
Run with your money in hand.
whatever   100 kW
Post by whatever » Mar 28 2020 8:26am
thought it looked a bit good to be true, adivice taken, thanks guys
