Help me troubleshoot this pack please. How are these voltages?
999zip999   100 GW
Re: Help me troubleshoot this pack please. How are these voltages?
Post by 999zip999 » Mar 20 2020 4:56am
Remember we are the punks of the punk but thank you for your time
eikido   10 W
Post by eikido » Mar 20 2020 6:05am
Thanks for everything.
Yes i'm from Sweden :)
john61ct   100 GW
Post by john61ct » Mar 20 2020 7:19am
Might be best to leave the BMS alone
and use a dedicated balancer unit that will do a better job at that function anyway
https://zhcsolar.com/product/ha02-battery-equalizer
https://tinyurl.com/yx4fn379
Or Chargery BMS16T/BMS16 Pro or BMS24T/BMS24 Pro.
Then can use with multiple packs, and does not interfere with your preferred charging protocol
eikido   10 W
Post by eikido » Mar 20 2020 7:38am
john61ct wrote:
Mar 20 2020 7:19am
I see.
Since there aren't any 13s balancers, what is your recommendation to balance?
Use something like the IMAX B6 and balance 6 cell parallels at a time?
https://www.skyrc.com/iMAX_B6_Charger
john61ct   100 GW
Post by john61ct » Mar 20 2020 8:48am
I just posted a bunch of dedicated balancers for you to look at!
Anything over 13S should handle 13S.
Balance **charging** is entirely different. That one is cr^p and only 6S anyway.
Even 12S gets very hard to find 14S crazy expensive.
But yes can be a great approach. To go that way, best to build 6S and 7S packs, charge them separated in an 8S charger like FMA PL8 or iCharger 4010-Duo, then reconnect to get 13S for discharging.
Next pack maybe?
john61ct   100 GW
Post by john61ct » Mar 20 2020 8:52am
Actually, an 8S charger could do each "half" of your 13S sequentially
just not at the same time, pretty inconvenient.
zeccato   100 W
Post by zeccato » Mar 20 2020 10:15am
I'd measure all the 13s while he's charging, to see the highest, or how far they go...
Full susp. folding 20 swxh r. (2011),. 02 2020 MacT8. batt. 48v. 25A Life (2012), and 48 7,5A a123 (2018?). Controller programmable EB3 12 FET. Charger Balancer 14s: TP1430C. Gophert CPS-6011 60V 11A. Mercury (rarely). Buzzer. https://www.google.com/url?sa=t&source= ... 6dXxc9-lNW
eikido   10 W
Post by eikido » Mar 20 2020 11:28am
Thanks all.
I'm very sorry @john61ct, i missed those balance chargers in the previous post, sorry.
I will try to get one of them.
Here are measurements fully charged.
1: 4.13
2: 4.12
3: 4.11
4: 4.10
5: 4.13
6: 4.12
7: 4.12
8: 4.13
9: 4.13
10: 4.12
11: 4.04
12: 4.12
13: 4.13
I guess 11 doesn't look good?
Largest difference:
4.13-4.04=0.09
Is that too much of a difference?
john61ct   100 GW
Post by john61ct » Mar 20 2020 4:09pm
eikido wrote:I'm very sorry @john61ct, i missed those balance chargers in the previous post, sorry
Those aren't "balance chargers".
They are "balancers" or sometimes "not protective BMS". Some do not require working with a charge source at all, they shuttle excess energy from the high cells to the low ones until everything is even, and work at whatever SoC point you prefer.
I would learn more about them maybe start a thread asking for feedback from any members that have owned them, before actually purchasing any.
And yes, most target getting cells within 3-5 mV, nearly 0.1V is a fair bit.
Could try bringing it up manually a bit with a suitable charge source, see how you go in the meantime.
Maybe even try a cheaper adjustable BMS just hook it up as needed while charging for balancing purposes.
Is the pack of a type where atomizing the cells to deal with them isolated would be a pain?
eikido   10 W
Post by eikido » Mar 20 2020 5:05pm
john61ct wrote:
Mar 20 2020 4:09pm
I see. I will create a new thread about those balancers. Thanks for that, i start to understand how they work and they are really interesting!
I will charge cell 11 manually to balance it with the other cells.
And for this question.
Yes it is:\
eikido   10 W
Post by eikido » Mar 22 2020 3:25am
After i fully charged the pack (cell 11=4.04v) and waited one day, cell 11 dropped to 4.00v (compared to highest cell voltage of 4.13v).
So i balanced cell 11 to 4.13v and after one day, it dropped to 4.06v.
The other cells have held their voltage for two days (one cell dropped 0.02v which should be ok).
Does this say anything or is this normal?
john61ct   100 GW
Post by john61ct » Mar 22 2020 7:56am
Is that a cell or a group?
Yes indicates weakness, IMO needs atomized load testing likely replacement
unless you're willing to let that cell / group capacity dictate the (much reduced) range of the whole pack
eikido   10 W
Post by eikido » Mar 22 2020 8:21am
john61ct wrote:
Mar 22 2020 7:56am
It's a group. It's 6P.
I will disassemble the whole pack, find the bad cell and rebuild it to a 5P.
I will use a liitokala lii-500s to find the bad cell.
Thanks.
john61ct   100 GW
Post by john61ct » Mar 22 2020 9:47am
May be more than one.
Ideally test them all discard the worst, try to get groups matched as close as possible.
An ESR tester would also be good.
Interesting cheap cap tester that, has it been well tested as accurate, as compared to the ZKETECHs or Maynuo?
fechter   100 GW
Post by fechter » Mar 22 2020 10:04am
eikido wrote:
Mar 22 2020 3:25am
You might want to repeat the test with the BMS unplugged. It's possible the BMS has a stuck-on balancing shunt. If you have good access to the BMS, you can also measure the voltage across all the balancing load resistors. They should be all zero.
eikido   10 W
Post by eikido » Mar 22 2020 10:41am
fechter wrote:
Mar 22 2020 10:04am
eikido wrote:
Mar 22 2020 3:25am
The bms does not have balancing function. Should I be worried about that? Are they really necessary?
zeccato   100 W
Post by zeccato » Mar 22 2020 11:32am
eikido wrote:
Mar 22 2020 3:25am
Does the battery do less miles (km) than before?
john61ct   100 GW
Post by john61ct » Mar 22 2020 11:54am
No protective-only BMS is fine
but every pack will likely need balancing eventually somehow.
It is true that any BMS can fail and wreck (a subset of) the pack (why some call them Battery Murder Systems)
or not if you catch the fault early
eikido   10 W
Post by eikido » Mar 22 2020 12:28pm
zeccato wrote:
Mar 22 2020 11:32am
eikido wrote:
Mar 22 2020 3:25am
Brand new. Charged full one time. I do have warranty but it's going to cost more to get it shipped back. Plus I have all equipment to rebuild it. K weld, pure nickel, kapton tape etc. Plus it's fun and educational so I appreciate all your guys help. I do read a lot and check YouTube vids.
It works fine down to 50% capacity. Then it turns off when loaded, even a little load, and won't turn on unless it is plugged into the charger very briefly.
zeccato   100 W
Post by zeccato » Mar 22 2020 1:17pm
eikido wrote:
Mar 22 2020 3:25am
I think that after 3 or 4 unloaded charges it will normalize, if charged up to at least 4v is fine, the difference is minimal.
In my opinion, I wouldn't do anything,
just sometimes the balance.
You use it for ebike?
eikido   10 W
Post by eikido » Mar 22 2020 4:16pm
zeccato wrote:
Mar 22 2020 1:17pm
eikido wrote:
Mar 22 2020 3:25am
It's for a 500w electric scooter. Burst >1000w.
999zip999   100 GW
Post by 999zip999 » Mar 22 2020 4:31pm
I would put some sense wires on it for ez monitoring and balanceing with a cellog and I use una6 hru the sense wire charger. 5s 5s and 3s.
eikido   10 W
Post by eikido » Mar 23 2020 5:29pm
Cell group 11 confirmed bad.
I'm lucky and managed to borrow a DC electronic loader.
When i reach ~3.488v then cell group 11 starts to get too much out of balance from the rest cell groups. Like 0.16-0.20v below the strongest cell group and the BMS shuts off.
Everything is fine from full charge (4.13v) down to ~3.5v and cell group 11 still stays well within tolerance.
I will try to rebuild this pack.
I'm trying to find BMS specs when the BMS's shuts off when a group gets too much out of tolerance.
Does anyone know a rough number? 0.15v?
john61ct   100 GW
Post by john61ct » Mar 23 2020 5:55pm
999zip999 wrote:I would put some sense wires on it for ez monitoring and balanceing with a cellog and I use una6 hru the sense wire charger. 5s 5s and 3s.
What is a "cellog" to you these days?
Been many years since the actual CellLogs were discontinued, afaict completely unavailable for a long time.
Also what are reliable suppliers of the UNRC chargers, ideally North American?
john61ct   100 GW
Post by john61ct » Mar 23 2020 5:59pm
eikido wrote:Everything is fine from full charge (4.13v) down to ~3.5v and cell group 11 still stays well within tolerance.
Really depends on the specific model BMS, they each differ.
Ideal is, that parameter is adjustable, along with the other more common ones.
Consider just getting a new pack, and use that one for only shorter trips, as is?
Likely not much useful range below 3.5Vpc anyway.
