Best 18650 cell for 3p 18A max
izeman   100 GW
Post by izeman » Jan 07 2020 2:25pm
I haven't seen any battery recommendation thread for a while, and I now need to build a new battery for a little TSDZ2 mid drive.
This really is a small motor that can do 10A sustained and 18A peak for a short period,
The battery will fit into a saddle bag and will be 14s3p. So every cell will see 3.3/6A.
I have worked with 25R, 30Q, 29E, 35E cells, and know Samsung cell quite well. But the other brands are unknown land. And I sorted those cells Samsungs cells in order of best to worse when it comes to ebike use - of course depending on power demand. And the demand was much higher for my other bikes.
For this small current I guess the 30Q would be fine, but also the LG HG2L sound great with 2800mAh and 20A, or any of the Sony VCT6 with 3000mAh and even 30A maybe?
What cell would you choose in regards of power/life/price ratio and why?
Honk   100 W
Re: Best 18650 cell for 3P 18A max
Post by Honk » Jan 07 2020 5:15pm
Why limit yourself to 3P unless the space available is really tight.
More cells in parallel increases cell life dramatically.
(typo corrected)
Efficiency is king!
amberwolf   100 GW
Re: Best 18650 cell for 3p 18A max
Post by amberwolf » Jan 07 2020 8:06pm
also, just so you both know, 3s means three cells in series.
pretty sure you both mean 3p, which means three cells in parallel.
recommend editing your title to match what i put in the title of this post.
izeman   100 GW
Re: Best 18650 cell for 3s 18A max
Post by izeman » Jan 08 2020 1:40am
Honk wrote:
Jan 07 2020 5:15pm
Why limit yourself to 3S unless the space available is really tight.
... saddlebag ... = 42 cells
izeman   100 GW
Post by izeman » Jan 08 2020 1:44am
Headrc wrote:
Jan 07 2020 9:03pm
Have you considered the Boston Power Swing batteries?
No. Haven't heard of before. But tbh they look like a 1s2p 18650 cell too me with neither high capacity nor high c-rate. And they would be impossible to fit into the space i have available.
spinningmagnets   100 GW
Post by spinningmagnets » Jan 08 2020 6:33am
Among the high-capacity cells, I have been hearing good things about the LG-Chem MJ1 cell...but, I don't know what they are selling for these days.
izeman   100 GW
Post by izeman » Jan 08 2020 7:39am
spinningmagnets wrote:
Jan 08 2020 6:33am
The MJ1 are 3.500mAh cells and can only do 10A. That's a bit to close to what i ask from them. I don't want them to be 80C hot.
eMark   100 W
Post by eMark » Jan 08 2020 9:30am
izeman wrote:
Jan 07 2020 2:25pm
Samsung 25R ... for power, life, price ... $3.25 x 42 = $137 (IMR). Cycle life has too many variables ... e.g. TLC vs abuse, the quality of your BMS ($30 vs $100), how often you charge to 4.05v vs 4.2v, how much and how often you discharge your pack (e.g. 3.0v vs 3.5v), etc, etc.
As you are well aware the cycle life longevity of the cells in your DIY 14S3P battery pack depends more on U than what new brand name cells best meet your requirements, whether its a $3.25 cell or a $4.99 cell.
Actually, i favor the 30Q (low DCIR for cycle life longevity), but it costs more ... $4.35 x 42 = $183 (IMR). Also, the 30Q is actually good for short bursts up to 20 amps even though it's rated at 15A. 30Qs 3000mAh rating is true; whereas 25R at best is only 2500mAh.
Honk   100 W
Post by Honk » Jan 08 2020 9:37am
Efficiency is king!
brone   10 mW
Post by brone » Jan 08 2020 10:14am
If Pajda is right the cheap M29 can do 3C at 100DOD for 1k cycles
izeman   100 GW
Post by izeman » Jan 08 2020 11:55am
brone wrote:
Jan 08 2020 10:14am
Who/what is Pajda? And with M29 you mean the LG 2850mAh cell? That's a 10A cell as well as I know.
LG seems to have a good life reputation it seems, so I may go with the MJ1 which is 3500mAh and a 10A cell as well. I hope voltage say will not be too massive. I hate it when the "fuel gauge" goes down 30% every time you "hit the throttle" ;)
brone   10 mW
Post by brone » Jan 08 2020 12:26pm
If I were to go for high C-rate cells I would go with the cheapest ones, because most of them are likely to last only 500 cycles.
eMark   100 W
Post by eMark » Jan 08 2020 12:54pm
deleted (double post)
eMark   100 W
Honk wrote:
Jan 08 2020 9:37am
30Q has actually bad cycle life.
docware is just beginning his cycle tests so have to wait and see how it progresses. FWIW, 30Q has the lowest DCIR of the several cells he is cycle testing ...
download/file.php?id=264006
As far as Pajda's post ... viewtopic.php?f=14&t=97844&p=1435146#p1433642 ... it's probably based as much on 30Qs use for vaping as for power tools which is not the most reliable indicator when it comes to 30Qs use in a DIY ebike pack. As i said before there are too many factors for Pajda to make such a conclusion (based more on vaping and power tools) without any actual 30Q ebiking experience himself. Doubt that Pajda has any such DIY ebiking proof on the current 30Q 141 cells.
izeman wrote:
Jan 07 2020 2:25pm
Of the 25R, 30Q, 29E and 35E which do you favor for your application?
If not 25R for power, life and price ... $3.25 x 42 = $137 (IMR) then which other one do you consider a better buy for price, power and cycle life longevity?
eMark   100 W
Post by eMark » Jan 08 2020 12:55pm
delete (double post)
Pajda   1 kW
Post by Pajda » Jan 08 2020 2:34pm
izeman wrote:
Jan 08 2020 11:55am
Who/what is Pajda?
:lol: :lol: :lol: :wink:
izeman   100 GW
Post by izeman » Jan 08 2020 4:30pm
Pajda wrote:
Jan 08 2020 2:34pm
izeman wrote:
Jan 08 2020 11:55am
Who/what is Pajda?
8) So would you recommend the MJ1 for my application as well? :wink:
Dak77   100 W
Post by Dak77 » Jan 08 2020 11:53pm
izeman wrote:
Jan 08 2020 4:30pm
Pajda wrote:
Jan 08 2020 2:34pm
izeman wrote:
Jan 08 2020 11:55am
Who/what is Pajda?
From what I've gathered from various posts pertaining to discharge loads in that neighborhood, LG HG2 would be my pick.
docware   1 kW
Post by docware » Jan 09 2020 6:00am
Yes, LG HG2 may be the proper cell, but be aware of the many fake HG2 cells. Advantage of such small battery pack is lower weight and size, disadvantage rather shorter lifetime.
viewtopic.php?f=14&t=101779&p=1488141#p1488141
LG MJ1 DCIR.jpg (172.67 KiB) Viewed 732 times
LG HG2 DCIR.jpg (170.92 KiB) Viewed 732 times
docware   1 kW
Post by docware » Jan 09 2020 7:21am
Maybe LG HG2L can be alternative .....
viewtopic.php?f=14&t=103161&p=1508960#p1508960
izeman   100 GW
Post by izeman » Jan 09 2020 8:01am
docware wrote:
Jan 09 2020 7:21am
HG2L is 3.000mAh 20A cell for 3.75€ - seems ok?! Cheaper than the HG2 for 4.25€
madin88   1 GW
1 GW
Post by madin88 » Jan 09 2020 3:17pm
6A per cell is pretty much in the middle because both, high C or high mAh cells, will give you similar range.
The high mAh cells have more V sag, but make up for it with more mAh, while the high current cells have more V and lower mAh, so usable Wh will be quite similar.
What would speak for high C cells is that you could charge them quicker (those high mAh cells all do not like to be charged with more than 1A), and in cold conditions you will like that they do not sag that much.
Honk wrote:
Jan 08 2020 9:37am
Unfortunately i had to find out that batteries where i used 30Q did drift apart after just 100 cylces (with 4.20V cut off, but still quite dissapointing).
I would take HG2 or Sony VTC6.
izeman   100 GW
Post by izeman » Jan 09 2020 3:53pm
Now that I rethought it, I took a look at my other pack of 30Q cells, which is a 15s10p pack, and this one sees 70A max. So very similar to the per cell current of the planned pack.
As the HG2 cell is not available at the moment I think I'll go for the VTC6 cell 3.000mAh for 3.95€. That way the whole pack will only be 9Ah and 48V, but this still is a much as most regular ebike have (~440Wh).
Only disadvantage I see is, that it seems to have an even lower cycle count than the 30Q, and much worse then the HG2.
