BMS question
seanau   10 µW
10 µW
BMS question
Post by seanau » Oct 25 2019 5:46am
Hello,
I wish to install a new BMS on my battery, as the last BMS had some issues. The original BMS was a 10S 36V 15A with only a B+ (ten ports) and a C- and B-
The new BMS has a P- C- and B+ ports.
Seems the battery was originally wired for a charge/discharge port.
I connected the C- but that did nothing, so i connected to the P- port and seems to charge. its now holding 38.1 volts cannot get an amps rating (using multimeter)
Am i suppose to connect the P- and C- together?
Thanks
