Planning a Vespa conversion
vdubjim   1 mW
Post by vdubjim » Jan 16 2020 12:03pm
Ive been reading here for a few weeks gathering info. I didnt see too much that was all inclusive about what i want to do.
I saw the 2 other vespa conversion, seems bunch of info left out.
Goals/Needs
-10" hub motor (space reasons)
-45mph top speed continuous (min)
-40-50 realistic mile range (min)
seems easiest planning is copy another. i found this bike and if specs are legit seems the way to go?
https://www.electrichunter.com/two-whee ... ic-scooter
Thinking QS 10"
https://www.aliexpress.com/item/3280877 ... 1544QdnVWQ
or
https://www.aliexpress.com/item/3280915 ... 1544Eq9FSQ
Battery 72v - 30AH
Recommendation on decent brand? Dont really want to make one this large myself, i see interesting cells on batteryhookup.
eee291   100 kW
Re: Planning a Vespa conversion
Post by eee291 » Jan 17 2020 7:09am
Welcome to the ES forum!
I've got a scooter that does 44Mph and goes about 25 miles on one charge, battery is a 72V 30Ah Lg Chem.
I recommend 45Ah or more.
You can't go wrong with a QS motor, capable of much more than what it's rated at.
Good luck with your build.
My scooter
vdubjim   1 mW
Post by vdubjim » Jan 17 2020 8:29am
Thank you.
vdubjim   1 mW
Post by vdubjim » Jan 18 2020 12:03am
Guess Kelly controller really isint in Texas? I figured I would ask a shop my questions, def not the answers I was looking for lol.
The 10" motor has 1-2KW version.
Which motor are you using?
You want to do 72km/h.
https://kellycontroller.com/shop/brushl ... otor-10in/
You can use 72V 6KW 10" hub motor.
You may use our KLS7245H controller for the motor.
https://kellycontroller.com/shop/kls-h/
As of the batteries,you may ask for the help from the batteries supplier.
Please provide the controller specification for them.
Thanks,
Fany
eee291   100 kW
Post by eee291 » Jan 18 2020 12:11pm
No, they are a Chinese company, asking them for advice isn't really recommended.
You'll have more luck with QS motors at least.
Here is what I've got in my scooter:
https://www.aliexpress.com/item/3281171 ... 19d97afb67
It does need a fan to cool it though since it is hidden near the battery.
Battery... make one or get one made :wink:
vdubjim   1 mW
Post by vdubjim » Jan 18 2020 12:15pm
eee291 wrote:
Jan 18 2020 12:11pm
You have this QS motor? How big is your scooter and speed etc?
eee291   100 kW
Post by eee291 » Jan 18 2020 1:11pm
Just read my first post, all the info is there.
vdubjim   1 mW
Post by vdubjim » Jan 18 2020 1:13pm
Hahaha, sorry didn't realize you posted that too
mistercrash   10 kW
Post by mistercrash » Jan 18 2020 8:22pm
Contact QS Motors and explain your requirements and they will recommend a good match between motor and controller for your project. I had a good experience with them when I did my scoot.
Send $10 at paypal.me/Ray1964 and you will be in my thoughts and prayers.
vdubjim   1 mW
Post by vdubjim » Jan 19 2020 9:46am
QS....
10inch 4000W Hub Motor 55H V3 Type: USD279
Kelly Controller KLS7245N: USD250
Twist throttle: USD4
Disc brake kits: USD25
72v battery
mistercrash   10 kW
Post by mistercrash » Jan 19 2020 1:19pm
Battery, Nissan Leaf modules?
vdubjim   1 mW
Post by vdubjim » Jan 19 2020 1:23pm
That's a good idea.
https://batteryhookup.com/products/niss ... b870&_ss=r
Wonder how much a bms and charger would be.
mistercrash   10 kW
Post by mistercrash » Jan 20 2020 12:01am
I have not shopped for these modules in a long while but this is by far the lowest price I have seen.
vdubjim   1 mW
Post by vdubjim » Jan 20 2020 1:29pm
QS says $169 shipping via FedEx.
vdubjim   1 mW
Post by vdubjim » Jan 20 2020 1:34pm
Saw the giant machined swing arm on here, I'll prob opt for something like this I found on Google images
vdubjim   1 mW
Post by vdubjim » Jan 24 2020 12:48pm
Very hard yo find a reasonable bolt on solution for leaf bms, and not too much on using standard bms.
Anyone know?
vdubjim   1 mW
Post by vdubjim » Jan 26 2020 9:33am
Found this post. Some good info if I can wade through the randomness.
viewtopic.php?f=10&t=85164
mistercrash   10 kW
Post by mistercrash » Jan 26 2020 1:32pm
I had the same problem trying to find a suitable BMS for my scooter a few years ago. So I made this, not a BMS but more of a LVA/HVA. Low voltage and high voltage alarm using 4 Cellogs 8M. It's been working for me.
Cell-Log with alarm_zpsgf0omzsr.jpg (33.5 KiB) Viewed 976 times
Cell-Log BMS_zpsyvbqxr1i.jpg (128.94 KiB) Viewed 976 times
vdubjim   1 mW
Post by vdubjim » Jan 26 2020 1:35pm
mistercrash wrote:
Jan 26 2020 1:32pm
That looks cool!
What cells?
vdubjim   1 mW
Post by vdubjim » Jan 26 2020 7:57pm
Walking around the garage forgot I have a test battery or 6, lol.
mistercrash   10 kW
Post by mistercrash » Jan 28 2020 1:26pm
vdubjim wrote:
Jan 26 2020 1:35pm
mistercrash wrote:
Jan 26 2020 1:32pm
That looks cool!
What cells?
10 Leaf modules
vdubjim   1 mW
Post by vdubjim » Feb 03 2020 3:21pm
Reading other posts, appears I need a contactor.
This one up to the task?
https://kellycontroller.com/shop/kzj-200a/
vdubjim   1 mW
Post by vdubjim » Feb 16 2020 7:30pm
Playing with a Honda swingarm. Why build if I can mod a bit?
HiRes   1 µW
Post by HiRes » Feb 23 2020 11:35pm
Vdubjim, I have completed a 1961 Vespa VBB project with a 52v 28.5 Ah battery from Luna cycle and a 3Kw QS motor. It has a top speed of 54Kph, or 32mph, and I've been riding it for a little over a year. You can read about my project at Modern Vespa (I'm not sure the Vespa community is ready to embrace an electric Vespa, but...) : http://modernvespa.com/forum/topic163759. I'd post more pictures if I could figure out how.
Although this scooter performs exactly as I intended, I am currently in pursuit of more speed. So I am rebuilding this machine with a 72v 24.5Ah battery from Em3ev, and a 4kw QS motor. This rebuild will require moving some components around and I think it will take me another month or two to finish. I will report my test results when I get it finished.
Lastly, since I've done it, I might be able to offer some insights for your project. I've learned so much from this forum, and I'd like to help others. Let me know how I can help you with your project.
