Small High Current Alligators?
rg12   100 kW
Post by rg12 » Feb 15 2020 5:26pm
Am looking for higher current alligators that aren't big like jump starter gators, something with more of a flat bite than the few teeth that actually touch the conductor...
Any ideas?
DogDipstick   10 kW
Re: Small High Current Alligators?
Post by DogDipstick » Feb 15 2020 6:41pm
Bahahaha
This wat u lookin 4?
They been around for a long timez Lolz.
" BED OF NAILS CLIPS"
-0r-
"Single Spike"
Your choice .
https://www.google.com/search?client=fi ... +cable+set
https://www.amazon.com/s?k=BED+of+NAILs ... _sb_noss_2
Not very obvious search terms, Eh? lol...... Screw Google IMO. Ask first. Google later.
If they dont suit you, look toward tig welding clams. They come in med-high current, all sizes. Easy plugin and unplug.
83.1v of Ironhorse XC.. :) :bolt: by Chevy :bolt: :D Broke 10 horsies :twisted: (..about 80% healed..).. :? Anybody.. what equals √3 times the line to neutral voltage? Asking for a friend.. :| (gottenymoem4115thangs?Yall?) :confused: Fabricator @ BSECo. Inc.
e-beach   1 GW
1 GW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Post by e-beach » Feb 15 2020 6:53pm
Unfortunately, current is current and mass is mass and small connectors just won't carry large current.
Although, I suppose I should ask just how high a current you are thinking about first?
How much amperage can a bed-of-nails 17awg carry....8 amps?
My first thought is to connect two pieces of 10 awg solid core wire to an existing alligator clip. File the inside contact points flat and use it like a 10 awg clip.
:D :bolt:
Favorite Quotes:
"This is L.A., sugar. There is no 'over the top." Chris Erskine
"At a certain point the entropy wins." Maria Helena Braga
Current Build: ProFlex 757 Expert full suspension. Yescomusa 36v 800w Rear DD, upgraded 10AWG solid core through axle phase wires. 15ah Headway, 1000+ cycles, 80% DOD 30A Tronsung controller.
Past: Trek 4500 Yescomusa 36v 800w front DD.
Liahona, Yescomusa 36v 800w generic front DD.
1992 Trek 800, Yescomusa 800w 36v front DD.
rg12   100 kW
Post by rg12 » Feb 15 2020 7:16pm
Still won't work as it's hollow, it's like a dog's mouth haha, you will get a bit more area but still super thin.
I think I've seen some rectangular ones somewhere that had those thin close lines as the rigid area and the whole area was touching and not just the sides.
Even in car jumper cables they barely touch with 4 teeth, it's horrible...
markz   100 GW
Post by markz » Feb 15 2020 10:43pm
https://www.be-electronics.com/category_s/2310.htm
https://www.be-electronics.com/product_p/bu-21cps.htm
more details on physical size here - https://www.accessotronik.com/product_p ... s_m285.htm
jaw opens
1.06" (27 mm) max; clip unmarked
(BU-21APN/CPN) and marked positive
(BU-21APS/CPS)
Material: zinc-plated steel (21A) or
solid copper (21C); Spring: steel
Length: 4.11" (104.4mm)
Federal Spec: CID AA59466-010
(BU-21CPN)
Rating: 50 Amps (21A) or
100 Amps (21C)
john61ct   100 GW
Post by john61ct » Feb 15 2020 11:07pm
Worst case put in a quality butt splice after cutting & stripping the wire.
Or leave a connector if you'll need to come back.
torker   1 MW
Post by torker » Feb 15 2020 11:32pm
300AMP COPPER WELDING GROUND CLAMP by LENCO https://www.amazon.com/dp/B008VFWCFW/re ... sEbTJMHV2S
Here you go. 😎😏
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 36 v x 20 amps
Specialized FSR Comp 9C 6*10 48v x 30 amps
rg12   100 kW
Post by rg12 » Feb 16 2020 5:16am
Thanks guys, those mueller look great!
