Relay for up to 100V DC?
rg12   100 kW
Post by rg12 » Jan 11 2020 4:43pm
I have this load tester with 5 units of 5ohm 1500w resistors.
I connect and disconnect manually to change current draw and want to connect all 5 to 5 relays and have 5 switches to increase the current with.
I'm using it with batteries up to 100V (24S).
So I have about 15A in average and 20A max at 100V for each resistor of 5ohm.
There are plenty of cheap relay boards on eBay like this one:
https://www.ebay.com/itm/250V-30A-4-Cha ... SwZ2BbpVPO
That go up to 30A but they are all rated 250V while if you look at the relay itself it says 250VAC/30VDC
Do you think I will fry it at 100V from a battery?
billvon   1 GW
1 GW
Re: Relay for up to 100V DC?
Post by billvon » Jan 11 2020 5:17pm
rg12 wrote:
Jan 11 2020 4:43pm
Yes. It will arc if you try to switch it under load.
--bill von
rg12   100 kW
Post by rg12 » Jan 11 2020 5:55pm
billvon wrote:
Jan 11 2020 5:17pm
rg12 wrote:
Jan 11 2020 4:43pm
Damn...
Any solution from eBay without going to digikey and ordering a single relay that will come without a pcb?
billvon   1 GW
1 GW
Post by billvon » Jan 11 2020 6:06pm
rg12 wrote:
Jan 11 2020 5:55pm
Damn...
If they are resistive loads, just use MOSFETs. They are cheap and easy to use. You can get a 120V, 60A MOSFET for about $1.50. You can drive them with TTL signals (0-5V)
If you really want an assembled thing, use a DC SSR. They are a LOT more expensive ($50 or so) but they can be connected with no other parts. A 200V 40A DC SSR is about $50 and comes with screw terminals.
--bill von
rg12   100 kW
Post by rg12 » Jan 11 2020 6:15pm
billvon wrote:
Jan 11 2020 6:06pm
rg12 wrote:
Jan 11 2020 5:55pm
Damn...
Found this for $7.5 shipped :D
https://www.ebay.com/itm/DD220D40-Ssr-4 ... Q&LH_BIN=1
It's rated for 40A and 220VDC which I doubt chinese ratings but I will run it at about 15-18A 70-100VDC
About less than half it's ratings...
Do you think I will need a heat sink for it?
Bikegirl   1 W
1 W
Post by Bikegirl » Jan 11 2020 9:18pm
I used a zeva contactor and precharger for a 72v system, works well with a cheap ass reducer giving 12v for the start system, and rated dc circuit breakers.
https://www.zeva.com.au › ...
Smart Precharger - Zero Emission Vehicles Australia
Gigavac P195 Minitactor - Zero Emission Vehicles Australia
AU $20.59 | Step down Transformer Electric DC Converter Adapter 48V 72V 96V TO 12V 10A USB 5V
https://a.aliexpress.com/NsYpON0G
Sent from my SM-G950F using Tapatalk
markz   100 GW
Post by markz » Jan 11 2020 11:09pm
Buying from Fleabay, I'd want 200Vdc and 40A for the sellers specifications, as they would be over exaggerated.
rg12   100 kW
Post by rg12 » Jan 12 2020 4:31am
markz wrote:
Jan 11 2020 11:09pm
That's exactly what I posted, 220VDC, 40A and I'm using less than half.
john61ct   100 GW
Post by john61ct » Jan 12 2020 5:41am
eBay sells robust contactors from Gigavac, Kilovac, Tyco, Schneider, ABB, Crydom, Crouzet
not just the poorly spec'd Chinese SS stuff
rg12   100 kW
Post by rg12 » Jan 13 2020 5:07am
john61ct wrote:
Jan 12 2020 5:41am
These brands are expensive especially when I need 5pcs.
I rather buy a chinese one and use half it's specs for $7 than buy 5pcs $70 brand contactors
john61ct   100 GW
Post by john61ct » Jan 13 2020 7:53am
Sure, not reco'ing for you specifically, just pointing out eBay is good for higher quality as well.
I've been collecting top notch DC contactors 200A many 500A, for an average of about $15 each.
One dud out of a dozen so far, and eBay refunded me in under 48hrs even though the seller tried to state "as is".
markz   100 GW
Post by markz » Jan 14 2020 12:10am
john61ct wrote:
Jan 13 2020 7:53am
That is a good run for dud ratio.
The AS-IS gotta laugh at that, I guess they are trying to take a jab at the buyers who are new(er) to ebay and dont know the rules precisely.
danielrlee   10 kW
Post by danielrlee » Jan 14 2020 2:28am
markz wrote:
john61ct wrote:
Jan 13 2020 7:53am
On eBay, "as is" is a fair declaration if the condition is specified as 'faulty or suitable for spares'. 'New' or 'used' condition means that the item must be "fully functional".
EBay policy states that buyers are not covered by the 'money back guarantee' for 'not as described' cases where the item condition is specified as 'faulty or suitable for spares'. In practice though, eBay often ignores its own policy on such matters.
https://TorqueTech.co.uk : Electric bike spares, parts & accessories : 10% discount code ’ENDLESS10
john61ct   100 GW
Post by john61ct » Jan 14 2020 6:23am
Yes those three options for condition is what rules for not as described.
Only "Not Working Parts Only" status removes warranty protection.
Writing As Is or No Returns is just a bluff if posted as Used.
But be careful about Local Pickup, that can hurt warranty claim, some say must be shipped by the seller
markz   100 GW
Post by markz » Jan 14 2020 4:40pm
Thats why I see some sellers always put down "For Repairs" so they got a bigger lee-way on the sellers part.
Overall ebay is on the buyers side if everything is truthful and honest.
john61ct   100 GW
Post by john61ct » Jan 14 2020 5:32pm
To the point it would be easy for a buyer to scam the sellers.
With great power comes responsibility, don't abuse it or they'll take it away.
